Scholar mrbietola
Bootloader won't jump when caches enabled
Hi, i modified a SPI srec bootloader but it doesn't work as expected, when jump to program.
I found the cause be the cache enabled ( not enabled on the original bootloader supplied by Xilinx). Why this is happening?
By the way the Microblaze preset setting is set to real time.
I have an other Microblaze with preset setting "Current Setting" and the modified bootloader works with cache enabled.
Is this expected behaviour?
How the processor preset will impact my code?
Scholar mrbietola
Re: Bootloader won't jump when caches enabled
I found the problem, it might help somebody else.
When i selected Real Time setting of Microblaze, it enabled the WriteBack Storage policy for the Data Cache.
Then with Data cache enabled in the bootloader maybe not all the data were transferred to DDR before the jump to the application code.
Scholar mrbietola
