Observer martin6314
Bug in the BSP standalone 6.5 of the sysmonpsu when used from C++
I am using the SDK 2017.4 for the processor psu_cortexa53_0 (ultrascale+) using the BSP standalone 6.5.
When importing the header file "xsysmonpsu.h" from c++ code I got the message
main.cpp:322:1: error: expected '}' at end of input
I traced this error back to the header file "xsysmonpsu.h", which contains the code
#ifdef __cplusplus
extern "C" {
#endif
as usual to allow using this library from C++. However, the counterpiece
#ifdef __cplusplus
#endif
is missing in this BSP header file. The work around is as follows: Wherever you use the header file from c++, add another line to close the bracket after:
#include "xsysmonpsu.h"
 } /* This is a hack, because xsysmonpsu.h contains a ifdef __cplusplus which is not closed */
This is a hack, but may help anyone out there until xilinx fixes the bug...
Martin
Re: Bug in the BSP standalone 6.5 of the sysmonpsu when used from C++
Hi @martin6314,
This is a know issue (CR-988034) and is fixed in master files of 2018.1.
Praveen
Hi @martin6314,
Praveen
