CANFD output signal can_phy_tx has no waveform
CANFD V2.0 IP output signal can_phy_tx has no waveform
    Use the canfd ip to simulate,but the output singal can_phy_tx has no waveform,only keep high level 1,the waveform is Figure 1,Figure 2 and Figure 3.
    The frequency of the s_axi_aclk and can_clk are all 20MHz.The input timing for the canip is accord with the required timing.
    I get the information from the xilinx forum the canfd ip need to be touched-up to use for xilinx vivado from version 17.2 through 18.2. My vivado version is 2017.4.
    Please help confirm.
    The forum link is as below.It seems the same issue as mine.
https://forums.xilinx.com/t5/Embedded-Processor-System-Design/CANFD-V2-0-IP-Core-goes-wild-at-any-bus-activity-Zynq7000/m-p/931869?advanced=false&collapse_discussion=true&filter=location&location=category:XlnxProd&q=canfd&search_type=thread
    The configuration address and data are show as Figure 2 and Figure 3.
canfd.PNGFigure 1
 canfd1.PNGFigure 2
canfd2.PNGFigure 3
