CDMA Not Triggering Interrupt with Vivado Project, but works with XPS
I am busy trying to use a CDMA to move data into the DDR on a Zynq Zedbaord. I have followed a tutorial on how to do this (http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_2/ug873-zynq-ctt.pdf) pg 51. I have been able to successfully use the CDMA when creating the system using XPS (and Plan Ahead). However, when I use Vivado to create the same system the interrupt doesn't trigger to indicate a successful transfer, neither does the transfer occur. It's a simple system but I can't seem to see why it works on XPS and not Vivado.
I would like to continue using Vivado as all my other designs are housed within it and it takes around 8 minutes to implement as opposed to 30 (for these two systems).
I've attached the two projects if anyone can see an obvious issue with the vivado project - please let me know
PS: You might notice that the XPS project has a BRAM included, that's just for my testing and not in use in this design.
Dean
Tags (4)
Re: CDMA Not Triggering Interrupt with Vivado Project, but works with XPS
Hi Dean,
I haven't had a chance to look at your projects, but i'd check the following things
- Are the interrupt lines from the CDMA hooked up to the GIC in hardware?
- Have you enabled interrupts in the CDMA registers?
- Have you enabled interrupts in GIC?
- Have you registered your handler with GIC?
- Do you have any errors in the CDMA status registers indicating that a transfer failed for some reason?
- Do you see Memory-mapped accesses being attempted once you kick off the transfers (via Vivado Logic Analyzer)
- Do you see all the data in your buffers in software?
www.xilinx.com
Hi bwiec,
Thanks for the quick reply. To answer your questions:
- Are the interrupt lines from the CDMA hooked up to the GIC in hardware? - Yes, there is one interrupt line connected directly to IRQ_F2P, should I be using an AXI interrupt handler?
- Have you enabled interrupts in the CDMA registers? - See below
- Have you enabled interrupts in GIC? - See below
- Have you registered your handler with GIC? - See below
For the 3 previous questions: I am using the exact same program (provided with the file ug873-zynq-ctt.pdf) and I assume the registers are being set correctly as the same code works with the XPS system.
- Do you have any errors in the CDMA status registers indicating that a transfer failed for some reason? - Not that I can see, no
- Do you see Memory-mapped accesses being attempted once you kick off the transfers (via Vivado Logic Analyzer) - Yes, but no interrupt is ever produced - I put a trigger on the intrrupt line in logic-analyser which never fires
- Do you see all the data in your buffers in software? - No
The Vivado project includes the exported SDK files as well as the code if you have a few minutes to check. It hsould be passed implementation and ready to run.
Dean
Hi bwiec,
Please see reply below...
Hi bwiec,
I have tried to recreate the Vivado project with the most basic components. Exported to SDK and then created a bare bones app based on the 'Periperal Tests' template. All tests pass except the CDMA one. If you open the test app you can see. The test app uses polling, so it doesn't seem to be an interrupt thing.
There must be something wrong with the hardware setup but it's very simple and I can't find it. Any ideas?
https://www.dropbox.com/s/0qfu6xetn3l50oc/CDMABasic.zip
Dean
