Observer snowman777
CPU and memory utilization metric monitoring?
Good morning everyone,
I was wondering if in vivado tools or anything that comes along with software has  metrics output that shows the CPU utilization and memory utilization live and/or behavior when running your application on the board ?  Any help on this owuld be much appreciate . thanks a lot.
Board : Zynq702
Jeremy
Scholar jmcclusk
Re: CPU and memory utilization metric monitoring?
The standard linux tool  "top" will run on the Zynq (on a serial console).   This is a quick and dirty method of showing utilization statistics.   If you have a GUI desktop running on the card, then you can probably use the system monitor application to show similar numbers.
If you don't have linux, but are running your application in bare metal, then gprof profiling can show you the utilization.
Observer snowman777
Sorry for the additional questions, I am a bit new at the console
how would this be implemented, when it is running the C++ application and sending information back on SDK,
where would i access the metrics ? you're saying connect via eithenet and linux kernel ? Do you know if there is any documentation for this , since this is new to me .
The system monitor , is this located in SDK or vivdado ?
thanks a lot
Jeremy
Scholar jmcclusk
your path depends on your environment.    Are you running Linux on the ZC702?   or bare metal?
Observer snowman777
I am launching my C++ application through SDK to run on the board
Jeremy
Scholar jmcclusk
That's bare metal,  so your best bet is to use profiling to get usage statistics.
Observer snowman777
Thanks a lot,
again excuse my lack of knowledge, profiling would be what exactly ?  thanks a lot
Jeremy
Scholar jmcclusk
Read this overview:  https://www.xilinx.com/support/documentation/sw_manuals/xilinx14_5/SDK_Doc/concepts/sdk_c_over_profile.htm
and then take a look at a tutorial showing how it's done:
https://forums.xilinx.com/t5/Xcell-Daily-Blog/Adam-Taylor-s-MicroZed-Chronicles-Part-64-Profiling-Zynq/ba-p/558003
