Visitor llqk
Call for help on UartLite Interrupt: Handler called but couldn't receive the input
Hi, Experts:
Please help to take a look at the following code.
I intended to show 1 char of the input string every time the handler was called.
But it didn't work the way as I expected.
Could you please tell me what's the problem?
Is that because the interrupt was not acknowledged in the handler?
But even if I added the acknowledgment it still behave the same way.
Abraham
#include "xparameters.h"
#include "xintc.h"
#include "xil_exception.h"
#include <stdio.h>
#include "xbasic_types.h"
#include "xuartlite.h"
#include "xuartlite_l.h"
void *CtrUartLite_ISR(void);
static XIntc intc;
static XUartLite CtrUartLite;
static int i=0;
int main(void)
int Status;
Status = XIntc_Initialize(&intc, XPAR_XPS_INTC_0_DEVICE_ID);
if (Status != XST_SUCCESS) {
return XST_FAILURE;
Status = XIntc_SelfTest(&intc);
return XST_FAILURE;
Xil_ExceptionInit();
Xil_ExceptionRegisterHandler(XIL_EXCEPTION_ID_INT,
(Xil_ExceptionHandler)XIntc_DeviceInterruptHandler,
(void*) 0);
Xil_ExceptionEnable();
Status = XIntc_Start(&intc, XIN_REAL_MODE);
return XST_FAILURE;
//start UartLite code from here;
Status = XUartLite_Initialize(&CtrUartLite, XPAR_UARTLITE_0_DEVICE_ID);
return XST_FAILURE;
Status = XUartLite_SelfTest(&CtrUartLite);
return XST_FAILURE;
Status = XIntc_Connect(&intc, XPAR_INTC_0_UARTLITE_0_VEC_ID,
(XInterruptHandler)XUartLite_InterruptHandler,
(void *)&CtrUartLite);
xil_printf("FATAL: Interrupt Controller Control connection failure\n\r");
return XST_FAILURE;
XUartLite_SetRecvHandler(&CtrUartLite, (void *)CtrUartLite_ISR, &CtrUartLite);
XUartLite_EnableInterrupt(&CtrUartLite);
XIntc_Enable(&intc, XPAR_XPS_INTC_0_CONTROL_UART_INTERRUPT_INTR);
while(1){}
return 0;
void *CtrUartLite_ISR()
u8 StatusRegister, temp;
xil_printf("..Enter ISR..\n\r");
if (i<3){
StatusRegister = XUartLite_GetStatusReg(&CtrUartLite.RegBaseAddress);
xil_printf("StatusReg----%X\n\r",StatusRegister);
temp = XUartLite_ReadReg(&CtrUartLite.RegBaseAddress,
XUL_RX_FIFO_OFFSET);
xil_printf("Recvd Char: %d\n\r\n\r",temp);
i++;
Testing result shown in the console:
Input: A (and Enter )
A
..Enter ISR..
StatusReg----64
Recvd Char: 0
..Enter ISR..
StatusReg----64
Recvd Char: 0
..Enter ISR..
StatusReg----64
Recvd Char: 0
..Enter ISR..
..Enter ISR..
..Enter ISR..
..Enter ISR..
......more
Visitor llqk
Re: Call for help on UartLite Interrupt: Handler called but couldn't receive the input
Finally I figured out the reason.
Even if I claimed the UartLite instance CtrUartLite,
the data I sent via the com port still goes to this address: XPAR_UARTLITE_0_BASEADDR
Don't understand the detail how it works.
But when I changed the code of the handler to the following it works well as I expected.
Wish this experience would help some other new learners.
//while (XUartLite_IsReceiveEmpty(XPAR_UARTLITE_0_BASEADDR));
temp = (u8)XUartLite_ReadReg(XPAR_UARTLITE_0_BASEADDR, XUL_RX_FIFO_OFFSET);
xil_printf("Recvd Char: %c\n\r\n\r",temp);
Visitor llqk
Hey
Your Uart lite is a custom peripheral that you add with the create or import peripheral of the Xilinx platform Studio ?
