Participant ssankar1
Cameral link reciver using Select io Wizard
I am trying to make  a camera link reciver  to get data from a high speed camera using Zynq FPGA The select io wizard in Vivado has a camera link operation . However it doesnt seem to be doing the right thing according to my understanding;. It takes in the differential clock from the camera link . and further divides it by 7 and sends it as the output clock. for the parallel data.
The o/p clock for the parallel data should be of same as freqquency the incoming pixel clock. There was a similar issue discussed in an older forum  for the Camera link transmitter ip.
http://forums.xilinx.com/t5/General-Technical-Discussion/Camera-link-transmitter-using-SelectIO-IP/td-p/418087
They had concluded that it is a bug in the IP.
Can anyone guide me on this.  Should we do the design on our own , or is there some work around .
Also in the camera link reciver IP there is no DDR option. It  greys out and the default is SDR.
Scholar trenz-al
Re: Cameral link reciver using Select io Wizard
cameralink should use SDR this is correct.
we are also doing CL ip core, but no ETA on release date yet
