Observer oska874
Can RPU send interrupt to APU?
Can RPU send interrupt to APU? And vice versa?
Re: Can RPU send interrupt to APU?
Hi @oska874,
Yes, RPU can send the Interrupt to the APU using IPI (inter processor interrupts).
Here we have an  IPI example for the PMU and RPU.
http://www.wiki.xilinx.com/Zynq+UltraScale+Plus+MPSoC+-+IPI+Messaging+Example
Also Please check the "IPI Interrupts and Message Buffers section" in Zynq MP TRM (ug1085).
Best Regards,
Srikanth
Hi @oska874,
Best Regards,
Srikanth
Observer oska874
thanks.
So gic is not accessisable for RPU?
@oska874
RPU has seperate GIC interface to handle RPU peripheral interrupts.
Kranthi
Best Regards
Kranthi
