Can't get interrupts to work on MicroBlaze IP Core
I am using the microblaze ipcore (not with xps) and I can't find documentation about how to get the interrupts to work. This is what I came up with but it is not working
    u32 id = XPAR_IOMODULE_0_DEVICE_ID;
    XIOModule iomodule;
    XIOModule_Initialize(&iomodule, XPAR_IOMODULE_0_DEVICE_ID);
    XIOModule_Connect(&iomodule,
            XPAR_IOMODULE_0_SYSTEM_INTC_INTERRUPT_2_INTR,
            (XInterruptHandler) ISR,
            (void*) 0);
    XIOModule_Enable(&iomodule, XPAR_IOMODULE_0_SYSTEM_INTC_INTERRUPT_2_INTR);
    Xil_ExceptionInit();
    Xil_ExceptionRegisterHandler(XPAR_IOMODULE_0_DEVICE_ID,
            (Xil_ExceptionHandler) XIOModule_DeviceInterruptHandler,
            &id);
    Xil_ExceptionEnable();
    XIOModule_RegisterHandler(XPAR_IOMODULE_0_IO_BASEADDR,
            XPAR_SYSTEM_INTC_INTERRUPT_2_MASK,
            (XIOModule_Timer_Handler) ISR,
            (void*) 0);
    XIOModule_Start(&iomodule);
I am able to read and write on the GPIO and the UART of the module so it is started, but the interrupts won't fire.
Thanks a lot.
Re: Can't get interrupts to work on MicroBlaze IP Core
Have you find a solution?
I'm very interested in!!
There are 2 ways to work with mb interrupts, using API or compiler language specific
Read
.http://chess.eecs.berkeley.edu/eecs149/documentation/th_ublaze_interrupts.pdf
or
Xilinx Embedded System Tools Reference Manual "Interrupt Management"
I have added som demo code
Hope it helps
/Frank
Re: Can't get interrupts to work on Arm zedboard custom peripheral
Hey
I search example of application in c language which use interrupt with a custom peripheral. AI am interessed by the processor Arm of Zynq.
