Can the initial data by COE be read out from the dual-port blockram directly without any write oprtation under simulation?
I supply a coe data for dual-port blockram .
if not issuing any write oprtation, can the coe initial data be  read out  from dual-port blockram  with only read operation after reset?
Re: Can the initial data by COE be read out from the dual-port blockram directly without any write oprtation under simulation?
hI @m006
Yes, you will read COE data if you issue read command without any write.
Deepika.
why is the rvalid/arready/rlast X state after reset 1600ns? it is ok with the blockram simulation environment by coregen.
I use the following sim file for smulation.
module blk_mem_gen_2 (
  s_aclk,
  s_aresetn,
  s_axi_awid,
  s_axi_awaddr,
  s_axi_awlen,
  s_axi_awsize,
  s_axi_awburst,
  s_axi_awvalid,
  s_axi_awready,
  s_axi_wdata,
  s_axi_wstrb,
  s_axi_wlast,
  s_axi_wvalid,
  s_axi_wready,
  s_axi_bid,
  s_axi_bresp,
  s_axi_bvalid,
  s_axi_bready,
  s_axi_arid,
  s_axi_araddr,
  s_axi_arlen,
  s_axi_arsize,
  s_axi_arburst,
  s_axi_arvalid,
  s_axi_arready,
  s_axi_rid,
  s_axi_rdata,
  s_axi_rresp,
  s_axi_rlast,
  s_axi_rvalid,
  s_axi_rready
(* X_INTERFACE_INFO = "xilinx.com:signal:clock:1.0 CLK.ACLK CLK" *)
input wire s_aclk;
(* X_INTERFACE_INFO = "xilinx.com:signal:reset:1.0 RST.ARESETN RST" *)
input wire s_aresetn;
(* X_INTERFACE_INFO = "xilinx.com:interface:aximm:1.0 AXI_SLAVE_S_AXI AWID" *)
input wire [12 : 0] s_axi_awid;
(* X_INTERFACE_INFO = "xilinx.com:interface:aximm:1.0 AXI_SLAVE_S_AXI AWADDR" *)
input wire [31 : 0] s_axi_awaddr;
(* X_INTERFACE_INFO = "xilinx.com:interface:aximm:1.0 AXI_SLAVE_S_AXI AWLEN" *)
input wire [7 : 0] s_axi_awlen;
(* X_INTERFACE_INFO = "xilinx.com:interface:aximm:1.0 AXI_SLAVE_S_AXI AWSIZE" *)
input wire [2 : 0] s_axi_awsize;
(* X_INTERFACE_INFO = "xilinx.com:interface:aximm:1.0 AXI_SLAVE_S_AXI AWBURST" *)
input wire [1 : 0] s_axi_awburst;
(* X_INTERFACE_INFO = "xilinx.com:interface:aximm:1.0 AXI_SLAVE_S_AXI AWVALID" *)
input wire s_axi_awvalid;
(* X_INTERFACE_INFO = "xilinx.com:interface:aximm:1.0 AXI_SLAVE_S_AXI AWREADY" *)
output wire s_axi_awready;
(* X_INTERFACE_INFO = "xilinx.com:interface:aximm:1.0 AXI_SLAVE_S_AXI WDATA" *)
input wire [127 : 0] s_axi_wdata;
(* X_INTERFACE_INFO = "xilinx.com:interface:aximm:1.0 AXI_SLAVE_S_AXI WSTRB" *)
input wire [15 : 0] s_axi_wstrb;
(* X_INTERFACE_INFO = "xilinx.com:interface:aximm:1.0 AXI_SLAVE_S_AXI WLAST" *)
input wire s_axi_wlast;
(* X_INTERFACE_INFO = "xilinx.com:interface:aximm:1.0 AXI_SLAVE_S_AXI WVALID" *)
input wire s_axi_wvalid;
(* X_INTERFACE_INFO = "xilinx.com:interface:aximm:1.0 AXI_SLAVE_S_AXI WREADY" *)
output wire s_axi_wready;
(* X_INTERFACE_INFO = "xilinx.com:interface:aximm:1.0 AXI_SLAVE_S_AXI BID" *)
output wire [12 : 0] s_axi_bid;
(* X_INTERFACE_INFO = "xilinx.com:interface:aximm:1.0 AXI_SLAVE_S_AXI BRESP" *)
output wire [1 : 0] s_axi_bresp;
(* X_INTERFACE_INFO = "xilinx.com:interface:aximm:1.0 AXI_SLAVE_S_AXI BVALID" *)
output wire s_axi_bvalid;
(* X_INTERFACE_INFO = "xilinx.com:interface:aximm:1.0 AXI_SLAVE_S_AXI BREADY" *)
input wire s_axi_bready;
(* X_INTERFACE_INFO = "xilinx.com:interface:aximm:1.0 AXI_SLAVE_S_AXI ARID" *)
input wire [12 : 0] s_axi_arid;
(* X_INTERFACE_INFO = "xilinx.com:interface:aximm:1.0 AXI_SLAVE_S_AXI ARADDR" *)
input wire [31 : 0] s_axi_araddr;
(* X_INTERFACE_INFO = "xilinx.com:interface:aximm:1.0 AXI_SLAVE_S_AXI ARLEN" *)
input wire [7 : 0] s_axi_arlen;
(* X_INTERFACE_INFO = "xilinx.com:interface:aximm:1.0 AXI_SLAVE_S_AXI ARSIZE" *)
input wire [2 : 0] s_axi_arsize;
(* X_INTERFACE_INFO = "xilinx.com:interface:aximm:1.0 AXI_SLAVE_S_AXI ARBURST" *)
input wire [1 : 0] s_axi_arburst;
(* X_INTERFACE_INFO = "xilinx.com:interface:aximm:1.0 AXI_SLAVE_S_AXI ARVALID" *)
input wire s_axi_arvalid;
(* X_INTERFACE_INFO = "xilinx.com:interface:aximm:1.0 AXI_SLAVE_S_AXI ARREADY" *)
output wire s_axi_arready;
(* X_INTERFACE_INFO = "xilinx.com:interface:aximm:1.0 AXI_SLAVE_S_AXI RID" *)
output wire [12 : 0] s_axi_rid;
(* X_INTERFACE_INFO = "xilinx.com:interface:aximm:1.0 AXI_SLAVE_S_AXI RDATA" *)
output wire [127 : 0] s_axi_rdata;
(* X_INTERFACE_INFO = "xilinx.com:interface:aximm:1.0 AXI_SLAVE_S_AXI RRESP" *)
output wire [1 : 0] s_axi_rresp;
(* X_INTERFACE_INFO = "xilinx.com:interface:aximm:1.0 AXI_SLAVE_S_AXI RLAST" *)
output wire s_axi_rlast;
(* X_INTERFACE_INFO = "xilinx.com:interface:aximm:1.0 AXI_SLAVE_S_AXI RVALID" *)
output wire s_axi_rvalid;
(* X_INTERFACE_INFO = "xilinx.com:interface:aximm:1.0 AXI_SLAVE_S_AXI RREADY" *)
input wire s_axi_rready;
  blk_mem_gen_v8_3_2 #(
    .C_FAMILY("virtexu"),
    .C_XDEVICEFAMILY("virtexu"),
    .C_ELABORATION_DIR("./"),
    .C_INTERFACE_TYPE(1),
    .C_AXI_TYPE(1),
    .C_AXI_SLAVE_TYPE(0),
    .C_USE_BRAM_BLOCK(0),
    .C_ENABLE_32BIT_ADDRESS(0),
    .C_CTRL_ECC_ALGO("NONE"),
    .C_HAS_AXI_ID(1),
    .C_AXI_ID_WIDTH(13),
    .C_MEM_TYPE(1),
    .C_BYTE_SIZE(8),
    .C_ALGORITHM(1),
    .C_PRIM_TYPE(1),
    .C_LOAD_INIT_FILE(1),
    .C_INIT_FILE_NAME("blk_mem_gen_2.mif"),
    .C_INIT_FILE("blk_mem_gen_2.mem"),
    .C_USE_DEFAULT_DATA(0),
    .C_DEFAULT_DATA("0"),
    .C_HAS_RSTA(0),
    .C_RST_PRIORITY_A("CE"),
    .C_RSTRAM_A(0),
    .C_INITA_VAL("0"),
    .C_HAS_ENA(1),
    .C_HAS_REGCEA(0),
    .C_USE_BYTE_WEA(1),
    .C_WEA_WIDTH(16),
    .C_WRITE_MODE_A("READ_FIRST"),
    .C_WRITE_WIDTH_A(128),
    .C_READ_WIDTH_A(128),
    .C_WRITE_DEPTH_A(8192),
    .C_READ_DEPTH_A(8192),
    .C_ADDRA_WIDTH(13),
    .C_HAS_RSTB(1),
    .C_RST_PRIORITY_B("CE"),
    .C_RSTRAM_B(0),
    .C_INITB_VAL("0"),
    .C_HAS_ENB(1),
    .C_HAS_REGCEB(0),
    .C_USE_BYTE_WEB(1),
    .C_WEB_WIDTH(16),
    .C_WRITE_MODE_B("READ_FIRST"),
    .C_WRITE_WIDTH_B(128),
    .C_READ_WIDTH_B(128),
    .C_WRITE_DEPTH_B(8192),
    .C_READ_DEPTH_B(8192),
    .C_ADDRB_WIDTH(13),
    .C_HAS_MEM_OUTPUT_REGS_A(0),
    .C_HAS_MEM_OUTPUT_REGS_B(0),
    .C_HAS_MUX_OUTPUT_REGS_A(0),
    .C_HAS_MUX_OUTPUT_REGS_B(0),
    .C_MUX_PIPELINE_STAGES(0),
    .C_HAS_SOFTECC_INPUT_REGS_A(0),
    .C_HAS_SOFTECC_OUTPUT_REGS_B(0),
    .C_USE_SOFTECC(0),
    .C_USE_ECC(0),
    .C_EN_ECC_PIPE(0),
    .C_HAS_INJECTERR(0),
    .C_SIM_COLLISION_CHECK("ALL"),
    .C_COMMON_CLK(1),
    .C_DISABLE_WARN_BHV_COLL(0),
    .C_EN_SLEEP_PIN(0),
    .C_USE_URAM(0),
    .C_EN_RDADDRA_CHG(0),
    .C_EN_RDADDRB_CHG(0),
    .C_EN_DEEPSLEEP_PIN(0),
    .C_EN_SHUTDOWN_PIN(0),
    .C_EN_SAFETY_CKT(0),
    .C_DISABLE_WARN_BHV_RANGE(0),
    .C_COUNT_36K_BRAM("32"),
    .C_COUNT_18K_BRAM("0"),
    .C_EST_POWER_SUMMARY("Estimated Power for IP     :     11.356588 mW")
  ) inst (
    .clka(1'D0),
    .rsta(1'D0),
    .ena(1'D0),
    .regcea(1'D0),
    .wea(16'B0),
    .addra(13'B0),
    .dina(128'B0),
    .douta(),
    .clkb(1'D0),
    .rstb(1'D0),
    .enb(1'D0),
    .regceb(1'D0),
    .web(16'B0),
    .addrb(13'B0),
    .dinb(128'B0),
    .doutb(),
    .injectsbiterr(1'D0),
    .injectdbiterr(1'D0),
    .eccpipece(1'D0),
    .sbiterr(),
    .dbiterr(),
    .rdaddrecc(),
    .sleep(1'D0),
    .deepsleep(1'D0),
    .shutdown(1'D0),
    .rsta_busy(),
    .rstb_busy(),
    .s_aclk(s_aclk),
    .s_aresetn(s_aresetn),
    .s_axi_awid(s_axi_awid),
    .s_axi_awaddr(s_axi_awaddr),
    .s_axi_awlen(s_axi_awlen),
    .s_axi_awsize(s_axi_awsize),
    .s_axi_awburst(s_axi_awburst),
    .s_axi_awvalid(s_axi_awvalid),
    .s_axi_awready(s_axi_awready),
    .s_axi_wdata(s_axi_wdata),
    .s_axi_wstrb(s_axi_wstrb),
    .s_axi_wlast(s_axi_wlast),
    .s_axi_wvalid(s_axi_wvalid),
    .s_axi_wready(s_axi_wready),
    .s_axi_bid(s_axi_bid),
    .s_axi_bresp(s_axi_bresp),
    .s_axi_bvalid(s_axi_bvalid),
    .s_axi_bready(s_axi_bready),
    .s_axi_arid(s_axi_arid),
    .s_axi_araddr(s_axi_araddr),
    .s_axi_arlen(s_axi_arlen),
    .s_axi_arsize(s_axi_arsize),
    .s_axi_arburst(s_axi_arburst),
    .s_axi_arvalid(s_axi_arvalid),
    .s_axi_arready(s_axi_arready),
    .s_axi_rid(s_axi_rid),
    .s_axi_rdata(s_axi_rdata),
    .s_axi_rresp(s_axi_rresp),
    .s_axi_rlast(s_axi_rlast),
    .s_axi_rvalid(s_axi_rvalid),
    .s_axi_rready(s_axi_rready),
    .s_axi_injectsbiterr(1'D0),
    .s_axi_injectdbiterr(1'D0),
    .s_axi_sbiterr(),
    .s_axi_dbiterr(),
    .s_axi_rdaddrecc()
endmodule
