Participant dpandya9488
Change clock frequency generated on Zynq 7000- ZC702 Eval Board at "runtime"
I want to change the clock frequency in ZC702 board at run time.. Means that right now I am generating a 100MHz clock using IP block- Clocking Wizard. But later I want to change it depending on the algorithm implemented on PL.. Means the clock should be changed depending on the computation results of algorithm in "run-time"..
Please advise if there is any provision or method I can implement to achieve this.. either through PL side or PS side..
Dhara
Re: Change clock frequency generated on Zynq 7000- ZC702 Eval Board at "runtime"
This can be achieved using the DRP ports.
Check below xapp
https://www.xilinx.com/support/documentation/application_notes/xapp888_7Series_DynamicRecon.pdf
Satish
