Code won't run to main()
    I've got a microblaze and a AXI4 SPI peripheral and I am using the test code to run a SPI self-test. However, my processor runs but will not get to main(). I do not have a DDR and I am running code off the BRAM.  I am new to the Xilinx SDK, how do I tell where this code is now residing?
Re: Code won't run to main()
Hi @vivienwwp ,
Can you check that the microblaze in not held in reset?
Florent
I am pretty sure the Microblaze is not in reset because I do see that is says "Microblaze(Running)"
Scholar watari
Hi @vivienwwp
Would you share your block design by jpeg or something ?
Best regards,
I was also going to ask where the should the master SPI clock be fed into at AXI Quad SPI? The microblaze is a slave at this point.
Scholar watari
Hi @vivienwwp
1) Make sure the polarity of reset_rtl_0 and other module's input reset port.
2) Fix input floating on microblaze_0_xlconcat module.
Best regards,
I am pretty sure the polarity is correct for reset_rtl_0.
As for microblaze_0_xlconcat, how should the input In0 and In1 be connected?
