Participant nturner
Configuring I2C on Custom Platform
I'm trying to configure I2C for a custom platform, but am not getting any signals on either SDA or SCL when I connect them up to an oscilloscope.
I have the following constraints set:
# IIC
set_property -dict {PACKAGE_PIN AA11 IOSTANDARD LVCMOS25 PULLTYPE PULLUP} [get_ports iic_scl]
set_property -dict {PACKAGE_PIN AA12 IOSTANDARD LVCMOS25 PULLTYPE PULLUP} [get_ports iic_sda]
And the following in my .tcl file:
create_bd_intf_port -mode Master -vlnv xilinx.com:interface:iic_rtl:1.0 iic_main
ad_ip_instance axi_iic axi_iic_main
ad_connect  iic_main       axi_iic_main/iic
ad_connect  sys_concat_intc/In14  axi_iic_main/iic2intc_irpt
ad_cpu_interconnect 0x41600000 axi_iic_main
My system_top.v:
module system_top (
  inout                   iic_scl,
  inout                   iic_sda,
  system_wrapper i_system_wrapper (
    .iic_main_scl_io (iic_scl),
    .iic_main_sda_io (iic_sda),
endmodule
Finally, my device tree:
amba_pl {
                #address-cells = <0x1>;
                #size-cells = <0x1>;
                compatible = "simple-bus";
                ranges;
i2c@41600000 {
                        #size-cells = <0x0>;
                        clock-names = "s_axi_aclk";
                        clocks = <0x1 0xf>;
                        compatible = "xlnx,xps-iic-2.00.a";
                        interrupt-names = "iic2intc_irpt";
                        interrupt-parent = <0x4>;
                        interrupts = <0x0 0x21 0x4>;
                        reg = <0x41600000 0x10000>;
                        eeprom@50 {
                                compatible = "at24,24c02";
                                reg = <0x50>;
Am I missing a setting somewhere for running I2C on any two arbitrary pins? I've already checked for any conflicts in the constraints and those pins are free.
Tags (4)
