Observer dchang3etagen
Conflicting values for Dist Baseaddr
Can someone please explain why the Dist Baseaddr do not match between xparameters.h and xparameters_ps.h?
xparameters.h
/* Canonical definitions for peripheral PSU_RCPU_GIC */
#define XPAR_SCUGIC_0_DEVICE_ID 0U
#define XPAR_SCUGIC_0_CPU_BASEADDR 0xF9001000U
#define XPAR_SCUGIC_0_CPU_HIGHADDR 0xF9001FFFU
#define XPAR_SCUGIC_0_DIST_BASEADDR 0xF9000000U
xparameters_ps.h
/* Canonical definitions for SCU GIC */
#define XPAR_SCUGIC_NUM_INSTANCES   1U
#define XPAR_SCUGIC_SINGLE_DEVICE_ID    0U
#define XPAR_SCUGIC_CPU_BASEADDR    (XPS_SCU_PERIPH_BASE + 0x00001000U)
#define XPAR_SCUGIC_DIST_BASEADDR   (XPS_SCU_PERIPH_BASE + 0x00002000U)
#define XPS_SCU_PERIPH_BASE     0xF9000000U
Re: Conflicting values for Dist Baseaddr
Hi @dchang3etagen,
Could you regenerate the BSP for HDF again and verify both files.
Looks to be a bug.
Praveen
I will check.
Which value is correct?
Hi @dchang3etagen,
xparameter_ps.h looks to be correct.
Praveen
I verified this is being generated as posted.
