Constraints and attributes for Microblaze
Dear Members;
 As far as I know, after instantiating a microblaze (using edk) into an ISE design, a separate constraints file for the microblaze is automatically generated. This is besides the user generated ucf file. I know the mhs and mss files, however I don't know how to access the microblaze specific constraint file.
Am I correct thinking that this is automatically generated and how can I find it? I am aware of the one under processor->data. However this doesn't have any constraints on the peripherals.
I do also get the following warning in synthesis:
:Xst:387 - The KEEP property attached to the net <Inst_processor/mdm_0/mdm_0/MDM_Core_I1/JTAG_CONTROL_I/Insert_Delays[3].local_sel_n> may hinder timing optimization. You may achieve better results by removing this property
Where can I make this change? I looked at the files under processor -> hdl and synthesis. I couldn't find it.
Any help is appreciated.
Instructor
Instructor
Re: Constraints and attributes for Microblaze
KEEP attributes are usually in the source file.  That could be a VHDL, Verilog or pre-compiled
ngc file.  For EDK designs, most of these files are "under the hood" so you don't normally
get a chance to modify them.
-- Gabor
-- Gabor
Instructor
Instructor
I'm not sure about your first question, but as for the warning message you should just ignore it.
The KEEP attribute is to prevent removal of signals that only connect to the JTAG debug port.  ISE
does not consider these as supplying an output to a pin, so they would otherwise be removed
and possibly break your JTAG debugger connection.
-- Gabor
-- Gabor
Thanks gszakacs!
I understand that the JTAG port connections have KEEP attribute on them so that they won't be removed.
But I am really curious to know where these attributes are put? I would expect a design file with this attribute is listed.
I am not being able to find it.
Best Regards,
Instructor
Instructor
-- Gabor
-- Gabor
Got it, thanks Gabor!
