Participant svenssonjoel
Correct protocol for starting (and restarting, over and over again) a OpenCL workgroup in the Zynq PL
Say that I have the hardware generated for an openCL workgroup in my PL.
  - It has a Programming-registers (control, group_id_x and so on registers) mapped to some memory address (0x43c00000).
  - it has a axi mem interface, through which it can fetch and store data.
  - programming registers are hooked to GP0 AXI master
  - memory "axi" interface is hooked to GP0 AXI slave
I have been very succesfully launching workgroups like this by doing the following:
  - write appropriate values into the "programming-registers" but saving "control" for last.
  - after that I set bit zero of control (for START)
As I understand it now I should be able to poll control until the done bit is set (bit 1).
But on occasions (and with workgroups that perform very heavy memory io) things get stuck and
reading the control register shows a value of 1 (in other words, the start bit is set). I did not really think
that should ever happen.
I am thinking I am missing some parts of this "protocol", maybe after telling the workgroup to start there
must be a delay before poking the control register again (of some ns) ? or is there something else ?
If any of you experienced hardware guys immediately know what is up here, please fill me in.
Thank you very much and best regards
Teacher muzaffer
Re: Correct protocol for starting (and restarting, over and over again) a OpenCL workgroup in the Zynq PL
I am not sure if things are different between c/c++ & opencl designs but my understanding is that ap_start bit is self clearing ie the user sets it and it stays set till done bit is set when ap_start get cleared automatically.
So what you observe seems to be expected.
You can also connect an interrupt to done so that you don't have to poll the done bit.
Thanks for that feedback, muzaffer.
It does look like my understanding was not too far off then.  The real problem in my question
is however the "getting stuck" part.
So say i do the following
loop:
if (done or idle) {
   start_the_hardware
goto loop
The above is the scenario that causes the "hardware" to (as i see it) freeze and the control register remains at 1 (forever!)
But I have experimented with small tweaks
loop:
usleep(10);
if (done or idle) {
   start_the_hardware
goto loop
And the stalling/freezing behaviour goes away. This is why I wondered if there might be a recommended time
interval between "poking" the control register after isuing a start.
usleep(10) is not a huge amount of time in relation to the PL (should be just one cycle of the hardware unit).
Thanks again and best regards
Sorry was a bit off there, usleep(10) is a large amount of time in relation to the PL ;)
I gave kudos on your reply, muzaffer. Moving over to using interrupts does sounds like a very good idea.
I still want to understand the details of what is going wrong with my current setup though.
