DHCP connection release after short time (LWIP UDP raw mode)
Hi to all.
I am facing problems with DHCP using LWIP raw mode with Ethernet lite core.
I am using the examples given in XAPP1026. To test the connection i continously send UDP packets (1472 bytes payload) to a PC with a UDP receiver created with LabVIEW. A router with DHCP is in between to assign an IP to the FPGA. To check the connection I am using Wireshark to detect packets. I call dhcp_fine_timer() and dhcp_coarse_timer() continously such as it is configured on XAPP1026 example, but after 1'30" aproximately I can see in wireshark how the connection is released by the FPGA.
So, what could cause this problem?? If I call continously these functions FPGA IP  should  be renewed correctly, shouldn't be?? What other thing can provoke this behaviour?? Is there some parameter in lwipopts.h or any other file that I am not taking into account??
This is the code on my main.c :
int main(){
	print("\n\r\n\r");
	print("..............Entering main...........\n\r\n\r");
	GenDummyData(); // Function to generate dummy data on DDR3 memory
	struct netif *netif, server_netif;
	struct ip_addr ipaddr, netmask, gw;
	// the mac address of the board. this should be unique per board
	unsigned char mac_ethernet_address[] = { 0x00, 0x0a, 0x35, 0x00, 0x01, 0x02 };
	netif = &server_netif;
	if (init_platform() < 0) {
		xil_printf("ERROR initializing platform.\r\n");
		return -1;
	xil_printf("\r\n\r\n");
	xil_printf("-----lwIP RAW Mode Demo Application ------\r\n");
	// initliaze IP addresses to be used
#if (LWIP_DHCP==0)
	IP4_ADDR(&ipaddr,  192, 168,   1, 10);
	IP4_ADDR(&netmask, 255, 255, 255,  0);
	IP4_ADDR(&gw,      192, 168,   1,  1);
    print_ip_settings(&ipaddr, &netmask, &gw);
#endif
	xil_printf ("El programa llega a antes de la función lwip_init()\n\r");
	lwip_init();
	xil_printf ("El programa ha ejecutado la función lwip_init()\n\r");
#if (LWIP_DHCP==1)
	ipaddr.addr = 0;
	gw.addr = 0;
	netmask.addr = 0;
#endif
	// Add network interface to the netif_list, and set it as default
	if (!xemac_add(netif, &ipaddr, &netmask, &gw, mac_ethernet_address, PLATFORM_EMAC_BASEADDR)) {
		xil_printf("Error adding N/W interface\r\n");
		return -1;
	netif_set_default(netif);
	// specify that the network if is up
	netif_set_up(netif);
	// now enable interrupts
	platform_enable_interrupts();
#if (LWIP_DHCP==1)
	// Create a new DHCP client for this interface.
	// Note: you must call dhcp_fine_tmr() and dhcp_coarse_tmr() at
	// the predefined regular intervals after starting the client.
	dhcp_start(netif);
	dhcp_timoutcntr = 50;
	TxPerfConnMonCntr = 0;
	while(((netif->ip_addr.addr) == 0) && (dhcp_timoutcntr > 0)) {
		xemacif_input(netif);
		if (TcpFastTmrFlag) {
			tcp_fasttmr();
			TcpFastTmrFlag = 0;
		if (TcpSlowTmrFlag) {
			tcp_slowtmr();
			TcpSlowTmrFlag = 0;
	if (dhcp_timoutcntr <= 0) {
		if ((netif->ip_addr.addr) == 0) {
			xil_printf("DHCP Timeout\r\n");
			xil_printf("Configuring default IP of 192.168.1.10\r\n");
			IP4_ADDR(&(netif->ip_addr),  192, 168,   1, 10);
			IP4_ADDR(&(netif->netmask), 255, 255, 255,  0);
			IP4_ADDR(&(netif->gw),      192, 168,   1,  1);
	// receive and process packets
	print_ip_settings(&(netif->ip_addr), &(netif->netmask), &(netif->gw));
#endif
	// start the application (web server, rxtest, txtest, etc..)
	//start_applications();
	print_headers();
	start_udp();
	while (1) {
			tcp_fasttmr();
			TcpFastTmrFlag = 0;
			tcp_slowtmr();
			TcpSlowTmrFlag = 0;
		udp_sample();
    // never reached
    cleanup_platform();
	return 0;
Any help is really appreciated.
Kind regards.
Re: DHCP connection release after short time (LWIP UDP raw mode)
Any Idea????
Should I post this question in Embedded microprocessor forum??
Thanks for your reply
