DMA interrupts not triggered when AMP
Hi.
I use AMP config with Linux on core0 and baremetal app on core1. Tools version is 2017.4.
I want to use Zynq PS DMA by core1 for data transfers between DDR regions. When I config DMA_PS and SCUGIC in baremetal finally I cannot get interrupt from DMA. In the same time AXI TmrCntr from PL is work properly in interrupt mode.
I wrote some example code that do not work on my system. May be сolleagues make a glance on it. The same code work if I run it on core0.
I also use -DUSE_AMP=1 preprocessor directive if it matters.
May be I shall not use DMA_PS at all in core1 becouse Linux grab it? May be I need some tricks with cache? Please help.
