DSOCM/ISCOM BRAM memories not working in V-4 FX40
really urgent (for my client), maybe there is some advice solution, symptoms:
PPC SoC design (ISE top) had no OCM memories, after adding them
they are readable and writeable from the XMD, but as soon as PPC software
uses them it crashes completly and instantly.
when i write something to DSOCM ram in XMD it reads back ok tough.
any super secret settings needed?
the design uses older deprecated EDK IP's it has been revuped 4 times
Antti
Re: DSOCM/ISCOM BRAM memories not working in V-4 FX40
Thank you Mike for the suggestions, they may come handy.
i guess i forgot to mention that i had problem in OLD design (not mine)
where i ADDED OCM memories?
(reading my post i see i said that AFTER adding ocm memories
meaning it was clear they where not present in original)
now i feel so stupid. how could i waste such amount of time
2.5 WEEKS, with such a silly problem.
getting old i guess. i had completly forgotten that i must
read page 165 in ug018.PDF
case closed.
it all works.
Antti
for others: if you have problem where DSOCM memory
doesnt work, make sure you have read and understand
the bit settings in DSCNTL register.
they are autocalculated by BSB generate, but not fixed
afterwards when system changes.
Hi Antti, long time no see.
First, when you're reading/writing DSOCM via the PPC, you're actually using the PPC to do it. Therefore, your DSOCM should be good. Now the ISOCM is a different beast. I've never been able to peek/poke that memory from the debugger, ever. I've only been able to program it in the bitstream.
Did you make sure to keep the proper memory 'distance' between the two memories? IIRC, I think there needs to be a 4MB difference between the addresses used for ISOCM and DSCOM. As such, you normally see the IS mapped to 0xFFFF0000 and the DS mapped to 0xFEFF0000.
HTH,
-- Mike
Hi Mike
hm,, i have tried zillion of variants
DSocm only, ISOCM only, both..
as soon as some of the OCM memory is accessed the PPC SW dies
and the XMD DOES read writre DSOCM OK
i had 0xE000_0000 and 0xD000_0000 as base addresses, I assumed it safe?
thanks for quick reply
believe it or not i am fighting this issue 3rd week.
so gettimg temperature already from it
Antti
Hm
if it doesnt work with xmd it would not work from system ace either then?
because i think the genace uses same method as xmd to load the memory?
small update: i have the ocm memories working on the target board with
EDK BSB generated demo design, so i am going to compare all connections
and parameters with the failing design in the hope to find the issue
but maybe it want help, so stil looking for extra advice
Antti
SystemACE uses the same commands as XMD to perform memory manipulations.
If you're going to initialize the ISOCM/DSOCM, if they're BRAM, just have it done as part of the image build (Initialize BRAM in EDK gui). That's the only way I've been 100% succesful with it.
thanks!
yes i know the ace gen internals.
what you say is SCARY !!
i need both the DSOCM/ISOCM and external DDR2 to be initialized from systemACE
and there is no way to say: please put .vectors to ISOCM (into bitstream)
and use the rest of the sections to init via ace/jtag
I did 99% of test while configuring from ACE, but eh stack/heap
are not needed init, so the system with DSOCM only should have
worked also from systemace
still many thanks, i will be carefull with this issue.
but eh, if that doesnt work (ocm init from systemace)
i have to put RED ALERT WEBASE this must be fixed!!
Antti
hm
i assume you tried
http://www.xilinx.com/support/answers/29511.htm
and it failed still?
Antti
Actually, you can create a system where the vectors are in BRAM and the system is in DDR.
When you build the ELF, you'd specify that the sections you want in the I/DSOCM would be placed there, and the rest in corresponding memory. This image is used for bitgen of the FPGA. Next, strip those sections out of the ELF and have only the DDR sections remaining, and feed that ELF to genace tcl script.
That should build you a system that you're looking for.
I've tried using the ISOCM mapping, but have had on/off success in it always working. I finally gave up on trying to get it to work and just always initialized my BRAM via an ELF.
Normally, I use the ISOCM only for my bootstrapping (bootloader at 0xFFFF_FFFC etc), because of these types of problems. That way the the lower instruction memory can be updated as the software runs, changing the interrupt vector table, etc.
case closed.
it all works.
Antti
Ah yes, the DSARC/DSCNTL settings. I ran into the same problem a while back as well. I set mine up once, and then had to go back to BSB, rebuild the system and then copy out the values into my larger design.
Ha
lucky you, i tried the same, but: the system has 125 input clock so 3:1 to clock ration in BSB is not possible.
so the values copied from BSB did not work
it SO STUPID. it would not cost xilinx a lot, to have the DSCNTL values editable as drop down combo box where you select the ppc:ocm clock ration etc..
but no, it has hex entry only
Antti
