Visitor vgimonkar
Debugging Microblaze for stack overflow
I am running a program on microblaze and I suspect that my stack is getting overflowed causing a crash in microblaze.
While building the microblaze we didnt add any exception flags and also we dont have access to printf.
The way I am debugging this crash is getting the stack pointer from via register int *stack_ptr asm("r1");
and from a MAP file generated while building the microblaze, I get the stack start address.
eg: .stack          0x00008c50      0x400
I know the stack end address based on the size of the stack. So stackSize/4 gives me the total pointers it can store.
I am calculating the percentageStackUsed = ((float)((void *)stack_ptr - (void*)stackStartAddr)*(stackSize/4))*100;
I am passing this variable percentageStackUsed to a common location were we can read out the number every other second. But I am not seeing any reasonable values.
I am not sure if this is a correct way to debug stackOverflow in microblaze. If this community has some suggestions please let me know
Visitor vgimonkar
Re: Debugging Microblaze for stack overflow
Hi Johnmcd,
thank you for your reply,
do you think using the stack_ptr ("r1") will give me the current location of stack? I was thinking my approach should tell me if the stack overflowed?
I will try your approach 2. next
A few thoughts:
  1. enable the microblaze 'Enable Stack Protection' option in the microblaze 'Exception' tab
  2. fill stack memory with a known value, after running app for a while, stop and review how much memory was changed from known value
  3. Use chipscope to monitor the axi or lmb addresses used
  4. connect chipscope to the microblaze trace port and set appropriate triggers
Visitor vgimonkar
Hi Johnmcd,
I've never tried using asm("r1") so did a quick test and it appears to work for me.
