Participant thburghout
Disable all interrupts
I want do implement a generic way of disabling all interrupts, specifically to be able to implement interrupt safe procedures in code used by all components (logging in this case). Is this possible at all? Do I need to disable each interrupt by hand?
Thanks for the help!
Thoma
Scholar ericv
Re: Disable all interrupts
@thburghout
What is the target platform?
If it's the Zynq, you can do it with:
    asm(" cpsid  I");
If it's on the UltraScale+:
   asm(" msr  DAIFSET, #2")
I can't provide the info for other platforms
Scholar ericv
@thburghout
    asm(" cpsid  I");
It was the Zynq, apologies.
Thank you for providing the information. I decided not to support interrupt safety within the logger due to the use of heap allocated object. I will leave your answer for others.
