Disabling interrupts to execute atomic block
Hello everyone,
I am currently using ZynQ 7020 for converter control.
There are multiple ISRs involved for timing and control and I wish to update some reference values in the main loop using an atomic block. Afer going through the forum and some other technical manuals(mentioned below), I have written the following lines of code in my main loop.
asm(" CPSID I");
v_LV[0] = V;
umin[0] = -0.9 * v_LV[0];
umax[0] = 0.9 * v_LV[0];
pmin[0] = umin[0] * v_LV[0];
pmax[0] = umax[0] * v_LV[0];
asm("CPSIE I");
I just wanted to know if this will work safely without any exceptional cases.
http://infocenter.arm.com/help/topic/com.arm.doc.dui0473m/DUI0473M_armasm_user_guide.pdf
https://forums.xilinx.com/t5/Embedded-Processor-System-Design/Disable-all-interrupts/td-p/883923
Pramod
Tags (3)
Scholar ericv
Re: Disabling interrupts to execute atomic block
@leo_skadoosh23
It will for regular interrupts (IRQ) but not for fast interrupts (FIQ).
Plus the 7020 is dual core and if the other core also plays with these variables you'll need a spinlock because disabling interrupts only applies to the core CPSID is executed on.
Scholar ericv
@leo_skadoosh23
Hello @ericv,
Thank you for your answer. I am not worried about FIQs being executed.
Just another follow up question, how to know which core has/uses all my variables?
Cheers,
Pramod
Scholar ericv
@leo_skadoosh23
you can get the core # using these 2 instructions:
   mrc   p15, #0, r0, c0, c0, #5  @ Read the MPIDR
   and   r0, r0, #3               @ Isolate the CORE ID bits
@ericv
Thank you for your help!
Pramod
