Visitor raj@1994
Displaying stored image in BRAM through VGA using Zybo
I stored image in BRAM in the form of .coe file and i can able to access the data successfully. Now i need to display the same image through VGA using zybo board. How can i make PS PL communication by c code ?  I have used attached block for BRAM access.
回复: Displaying stored image in BRAM through VGA using Zybo
Hi raj@1994
From the block design you post, it seems great. The only thing you need to check is the vga_driver is satisfied the timing vga spec required.
It's more effective to simulate it or you can direnctly try it on the hardware.
Hi raj@1994
According to the block design you post, the BRAM has connected to the PS by AXI bus, so the PS can directly access the BRAM in the PL by C code(Xil_Out32 and Xil_In32), the base address and length can be set in the "Address Editor"
For VGA display, where do you want to add the vga display function, PS or PL? I think it's better to add this function in the PL.(As I know, on the ZYBO the vga port are connected to PL). If so, it's better to design a channel which the VGA display module can directly read the image bram in the PL, without through PS.
Visitor raj@1994
Thanks for your reply.
As you suggested i have added vga ip in PL side without using PS. I have attached block diagram ,VGA IP code as well as coe file stored in BRAM. could you plz verify the below design ?
Hi raj@1994
Mentor watari
Mentor
Hi raj@1994
You pay attention followings and must be followed VESA video timing.
- Clock frequency
- Polarity of HSYNC and VSYNC
Best regards,
Visitor raj@1994
Hi All,
I'm able to display the image in VGA without using PS.
