Participant ucabsdp
Div 5.1 giving incorrect results for signed negative inputs
I am using Div Gen 5.1 to generate a divider, i have found when an input is -ve and the other +pv it fails to give the correct result.
I am using this as part of a hardware design to be presented in a conference and need this issue resolved asap!
Sam
--I would also like to note, Xilinx software has been a constant battle to use (over the last 2 years!) with numerous bugs.
Tags (3)
Participant ucabsdp
Re: Div 5.1 giving incorrect results for signed negative inputs
I am running this in 32 bit as I had too many bug in 64 bit, but would this problem be resolved in 64? I am using vivado 2013.3, is this issue resolved in later versions? I am skeptical to upgrade as I know there will be another whole host of bugs I iwll have to learn to work around!
We don't have any known issue's which you have described.
Can you attach a simulation snapshot showing what you are seeing and what you are expecting to look at it and give you further suggestion on this.
Satish
Participant ucabsdp
The I have worked out the issue is when the result is 0> x >-1 ,  i.e just negative fractionals quotient = 0, the quoitent part is not signed extended to a negative.
I guess then the question is how can I construct a reliable fixed-point result from the axi-result format Quotient-Frac, in the case that there is no quotient and I need to sign extend myself.
Participant ucabsdp
