Enabling zynq PS UARt
Hello All,
I have 2 questions.
1) I have a zynq zc 7020 processor. I need to utilize the UART0 of PS and connect it with my WIFI module CC3200. CC3200 is a 4 wired UART. I want to know whether this can be done on vivado? What is the procedure to do it. Should i connect the UART signals in the Zynq PS to the CC3200 by writing a HSDL code?
2) Can I generate a constraints file for the PS subsection by enabling the PS UART? Or is it only if I connect the AXI GPIO or some submodules that i can generate the constraints file?
Community Manager
Community Manager
Re: Enabling zynq PS UARt
You can enable UART0 in Zynq processing system of block design.
Externally, you can connect Wifi pins to the respective MIOs.
Thank you for the replly. I will need only Tx, Rx, RTS and CTS signals of UART 0. Do I need to use AXI UART 16550 ip core to bring these signals to the outside world so that they can be connected to the CC3200 module on my PCB? Please confirm.
You can pull out PS UART signals to PL section using EMIO - this way you will not need the AXI UART 16550 IP. Check fig 19-1 in Zynq TRM:
http://www.xilinx.com/support/documentation/user_guides/ug585-Zynq-7000-TRM.pdf
Okay. Is the AXI UART 16550 for the 3rd UART which I may create in the PL? To bring PL uart signals externally?
hi all
I have a problem. I have a zybo board zynq7000, I want use UART PS, what Pins use zybo for send and receive data? i need a code for send and receive a message.
please help me. Thanks.
