Observer cascade99
Erase flash failed
I was using SDK2016.2 to "Programing Flash" but got error:
CortexA9 Processor Configuration
Version.............................0x00000003
User ID.............................0x00000000
No of PC Breakpoints................6
No of Addr/Data Watchpoints.........4
Processor Reset .... DONE
SF: Detected S25FL128S_64K with page size 256 Bytes, erase size 64 KiB, total 16 MiB
Performing Erase Operation...
ERROR: attempting erase past flash size (0x1000000)
Erase Operation failed.
INFO: [Xicom 50-44] Elapsed time = 0 sec.
ERROR: Flash Operation Failed
Anybody know why? I checked the cable, looks fine.
Re: Erase flash failed
Hi @cascade99
Please check where the similar topic is discussed.
https://forums.xilinx.com/t5/Embedded-Linux/Unable-to-boot-petalinux-from-flash/td-p/555692
Thanks,Vijay
Hi @cascade99
Thanks,Vijay
Observer cascade99
It turned out that the my .bin file is too big for single QSPI, i need set to dual parallel when I do Program Flash.
