Observer xx402709844
Error when building project on sdsoc
I am trying to build a FFT_iFFT project targed my zybo using SDSoC but there comes the following error. The HLS step works fine and I thinks such error comes after that. Is there anyone knows how this error comes and how to solve it?
By the way I am using my own HLS_TCL file, so I changed the sds++ command.
Re: Error when building project on sdsoc
This may be bug in function
https://forums.xilinx.com/t5/High-Level-Synthesis-HLS/Co-simulation-failinf-for-example-project-fft-ifft/td-p/702981
run other design if its not tool related issues
Thanks and Regards
Balkrishan
