Visitor fictive
Ethernet communication / AXI bus
I hope I'm in the right forum..
i want to say that i have read a lot of manuals, but I think i miss it.
I have two question... the first one is how do I use the Ethernet ports of the microzed..for instance I want to get data via this connection and to send data.. is there any guide to use that port?
the second question is: I heard that the microzed had an axi bus which connects everything on the board..is that right? i can't find it or how to use it...is that the AMBA bus? i herad that this bus is on the silicon, right?
thank you !
Teacher muzaffer
Re: Ethernet communication / AXI bus
You should read the ug585 Zynq Technical reference manual.
Ethernet is described in chapter 16 and the AXI bus, or the interconnect which is comprised of many different AXI busses is described in chapter 5.
