Participant afilgueras
Ethernet issues on ZC702
I'm experiencing some issues with ethernet in a ZC702 board.
The issue rises when I try to debug an application remotely.
When gdb in the host machine tries to read some files in the target through NFS, I get some error messages.
macb e000b000.ethernet eth0: DMA bus error: HRESP not OK
Then NFS stalls and any subsequent operation over nfs hangs.
I am using linux 4.6 from the 2016.3 xilinx release.
Re: Ethernet issues on ZC702
@afilgueras Just to make sure the Ethernet interface ion the board is fine, did you run the BIST test for Ethernet?
- Giri
There's no such thing as a stupid question. Feel free to ask but do a quick search to make sure it ain't already answered.
Keep conversing, give Kudos and Accept Solution when you get one.
Check below Answer Records. They may help to find debug clues
https://www.xilinx.com/support/answers/51616.html
https://www.xilinx.com/support/answers/68057.html
https://www.xilinx.com/support/answers/54012.html (In case if board problems exists)
I've set up an older kernel (3.19) that I used some time ago.
When using this kernel, everything works fine so it does not look to me like a HW failure.
I'm using the same bitstream, device tree and bootloader. I only changed the linux image
I also checked the suggested answer records, but I could not see anything useful :(
I've been digging a little more in this problem.
Checking dmesg I found some suspicious messages
During boot:
init: idmapd main process (1807) terminated with status 1
init: idmapd main process ended, respawning
init: idmapd main process (1836) terminated with status 1
init: idmapd main process (2059) terminated with status 1
init: idmapd respawning too fast, stopped
The first time I access a nfs file (zc702 is the nfs server):
NFSD: unable to generate recoverydir name (-2).
NFSD: disabling legacy clientid tracking. Reboot recovery will not function correctly!
I think this can be somehow related as the error seems to be triggered when gdb accesses some files through NFS.
Visitor rahul_cg
Dear Team,
I am using xillinx linux on with xc7z020clg400-1 part.
Kernel is Linux-4.9.0- xillinx.
when i try to download any file from ftp halts and below error is shown on console.
macb e000b000. ethernet eth0: DMA bus error: HRESP not ok.
i have already check with solution mentioned on below site
https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/commit/?id=7a3cc2a7b2c723aa552028f4e66841cec183756d
can you please help me out to resolve this issue.
@afilgueras Did you ever solve this NFS server issue? I'm looking to implement an NFS server on the Zynq and am investigating to see if other people have successfully done it.
Thanks!
Solution is in https://forums.xilinx.com/t5/Embedded-Linux/ZC706-ethernet-issue-with-Petalinux-2016-3/m-p/734574 .
