Participant diy_a
FPGA done_LED is not working after flashing the bitstream file... How to make it work?
Hai .,
i had bought Zybo Kit 7000 series Family.
i had flashed the Zynq boot image with the following offset values successfully on Zynq Board via Xilinx SDK (ver: 2016.4)
                     fsbl.elf
                     system_wrapper.bit
                     U-boot.elf
                     U-image 0x600000
                     dtb file 0xA00000
                     ramdisk 0xA20000
But the FPGA done_led is not working automatically after a power cycle.
on the other hand, if i program the FPGA MANUALLY via Xilinx SDK , it works and kernel image loads successfully from QSPI Flash.
How to Make FPGA done_LED works automatically?
Thanks in Advance..
Scholar pratham
Re: FPGA done_LED is not working after flashing the bitstream file... How to make it work?
@diy_a This one would resolve your issue.
https://forums.xilinx.com/t5/Embedded-Linux/Where-does-U-Boot-saveenv-to/td-p/532915
-Pratham
Hi @diy_a,
When programing the flash, make sure you have selected the correct type of flash:
This should be qspi single for Zybo.
Participant diy_a
hi @florentw
        thanks for the reply...
         But the thing is i had already given the Flash type as qspi_single., still fpga_done LED not working. what should i do now?
 Thanks in advance.,
Hi @diy_a,
1. Try to generate a .BIN file and boot from SD card.
2. If this works, try to use the .BIN file to program the Flash memory.
Scholar pratham
@diy_a My guess is you have not set the mode pins to QSPI boot. Set mode to qspi boot and you should be able to boot from the flash after power up.
Refer the attachment.
-Pratham
Participant diy_a
Actually i had set the modeboot as QSPI Boot already and followed the same procedures as you said., still the FPGA done_LED is not set after a power cycle.
Scholar pratham
@diy_a Weird, Could you enable the debug prints in the FSBL and post your terminal prints here?
#4
https://www.xilinx.com/support/answers/59174.html
-Pratham
Participant diy_a
Hi @pratham
          Hereby I have attached two log files.
                   1. fsbl-bit.log
                   2. fsbl-no_bit.log
1. fsbl-bit.log
           1)  As you said, I have enabled the debug prints in fsbl_debug.h file and created a boot image using Xilinx SDK 2016.4 with fsbl.elf,system_wrapper.bit and u-boot.elf .
           2)  Flashed the boot image via xilinx sdk.
           3) Power off and on the zybo board.
           4)  FPGA_done led is set.
                 ( NOTE: i have'nt loaded the kernel image. So leave it )
           5) U-boot prompt is working perfectly.
2. fsbl_no-bit.log
          1)  After giving "saveenv"  in u-boot prompt and Power OFF  and ON the zynq board , the FPGA_done bit is not set.
          2) Only when i program FPGA via Xilinix SDK manually,  fsbl starts booting as shown in log fsbl-no-bit.log
What is the reason behind this behaviour and how to solve this..?
Scholar pratham
-Pratham
Participant diy_a
Hai @pratham .,
Thanks for the solution ., it worked perfectly
