Participant perencia-wc
FSBL attach to target debug
Is there any way to debug FSBL attaching to target from the SDK or XSCT while in SD boot mode ? If I create the FSBL from the SDK and debug it I'm unable to reproduce the same problem. I've already enabled the debug traces, but I need to dig deeper and I don't want to put lots of traces.
Re: FSBL attach to target debug
A quick way is to add a delay loop to the beginning of main() and attach while this loop is running. Then you can place cursor after loop and right click->move to line. Add the delay loop on entry to stage 2. This way, psu_init/ps7_init will already have ran. Another method is to add a 'ticker' which outputs a char every second and waits for uart input before continuing.
Three more things:
  1. There is an AR that describes how to disable Link Time Optimization (LTO) in order to make sence of single stepping through code
  2. If mpsoc, there is another AR that describes the writes needed to enable jtag (3 or 4 register writes)
  3. If debuging drivers (BSP src), add -O0 to extra compiler flags
But beware that disabling optimizations will cause the FSBL to grow larger and possibly not fit in memory anymore. xfsbl_config.h contain defines that you can turn off/on to reduce FSBL functionallity and therfore decrease memory footprint.
#include "sleep.h"
main()
for(int i=0; i<100000; i++) {
sleep(1);
Three more things:
#include "sleep.h"
main()
sleep(1);
Yuou can attach to a running target in SDK debug configurations and add your symbol information. You can then reboot and stop at main.
However, as John mentioned, you need to remove opt
