FreeRTOS + LWIP socket mode
I was running FreeRTOS older version with Vivado 2014.4 on an older Xilinx Development board for ZC706. I had to upgrade Vivado because I wanted to run ethernet on a newer device (xc7020clg484) which had support for Vivado versions 2015.2 and later only.
However, I am not able to succesfully run LWIP in sockets mode in 2015.2 since the BSP is not able to build without errors . I tried to upgrade to 2015.4 to see if there is a fix. I saw a response in some other discussion that FreeRTOS Socket API has known issue in 2015.4 as well. Is this true?
What is the best Vivado/SDK version for me to be able to run socket API with freertos ?
Sowmya
Re: FreeRTOS + LWIP socket mode
There is an SDK 2016.1 project that uses FreeRTOS with lwIP documented on this page which may help as a reference http://www.freertos.org/RTOS-Xilinx-Zynq.html
Richard.
+ http://www.FreeRTOS.org
The de facto standard, downloaded every 4.2 minutes during 2015.
+ http://www.FreeRTOS.org/plus
IoT, Trace, Certification, TCP/IP, FAT FS, Training, and more...
