Visitor amamiya_ren
Gpio interrupt: interrupt is called after button is released
I connected 2 buttons to a GPIO instance and enabled interrupt. My expectation is each time one button is pushed a interrupt is called. However, the interrupt is also called when I released the button. How can I cancel the interrupt caused by button release?Here is my handler code:
void Intr_Handler(void *InstancePtr){
	int value;
	XGpio_InterruptDisable(&itr,XGPIO_IR_CH1_MASK);
	if ((XGpio_InterruptGetStatus(&itr) & XGPIO_IR_CH1_MASK) !=
			XGPIO_IR_CH1_MASK) {
				return;
	value = XGpio_DiscreteRead(&itr,1) - 1;
	xil_printf("Interrupt valid, Button %d is pressed\r\n",value);
	(void) XGpio_InterruptClear(&itr,XGPIO_IR_CH1_MASK);
	XGpio_InterruptEnable(&itr,XGPIO_IR_CH1_MASK);
	XTime_GetTime(&itr_start);
Visitor amamiya_ren
Re: Gpio interrupt: interrupt is called after button is released
@abhinayp Thank you! I have figured it out a couple of days ago: The Gpio interrupt send a pulse when the input changes. When the button is released, the input change from 1 to 0, and an interrupt is called. I solve this by removing Gpio interrupt and connecting the button to IRT_F2P directly.
Hi @amamiya_ren,
1) Enter the main loop
2) User pushes down the button - this makes the program enter another loop that will run the program. Once the program has finished, break; out of the loop back to the main where we wait for the button to be pushed again.
Best Regards
Abhinay PS
Give kudos to a post which you think is helpful and reply oriented.
Visitor amamiya_ren
