HDF file missing files inside
Hi, i'm facing a very frustrating issue and I can't, for the hell of me, understand what's going on..
Sometimes when I make a vivado project for a ultrascale+ device (Ultra96 board) when I export to hardware, the .hdf file is missing the psu source files.
Here is what the right content of a .hdf file should be
Here is the content of what i'm getting right now, you can see that the required .c and .h files are missing
without those, a petalinux project never compiles..
I always do the same manipulations, creating a vivado project targeting the Ultra96 board, creating a block design, populating it, creating hdl wrapper, generate bit stream, export hardware(include bitstream), open sdk( just in case)
Thank you
Re: HDF file missing files inside
Have you bd files inside you bd?
Hi! No I only have a single top level block design instantiation the zynq, an interconnect, my custom ip, a processor reset and thats it
I simply restarted an other project from scratch and this time everything works as expected... I occurs to me intermittently :S previous time was a month ago
