Visitor bluepaz
Hardware in the loop simulation using Vivado
Does anyone know if it is possible to do HIL simulation using Vivado 2014+ and if so a guide to getting started with it. I see the xapp744 application note but that uses ISE.
Re: Hardware in the loop simulation using Vivado
As of 2015.1 Vivado -> It is not possible to do HIL simulation using Vivado. It is a roadmap item. You can use XAPP744 to do HIL simulation in ISE.
Debraj
Visitor aasufi
How about ... now?
