Newbie rmpresto
Help Using __attribute__ ((__packed__)) Microblaze
Hey guys,
This may seem like a dumb question because there are examples over the web using __attribute__((_packed)), However I am not sure if it is intended to be used the way I am trying to use it since I never get the result I am looking for.  For example
Sturct my_sturct{
           short a;
           short b;
Struct __attribute__((_packed_))  size{
           short x;
           short y;
           short z;
          my_struct c;
My thought is that the size of the struct should be packed to 10 bytes or 12 bytes with the 2 extra at the end, however it adds padding between short z and m_sctruc c.  I need them to be pack.. or maybe its the way I call the struct is the problem such as
 I have an array say:  char my_array [12] = {0,1,2,3,4,5,6,7,8,9,10,11};  // total of 12 bytes
I want to fill the sturcture using this array
so
size struct_fill;
struct_fill  = *(const size*) my_array;
by doing this my structure is filled but is miss alligned when it gets to filling up:
short x = 0x01
short y = 0x23
short z = 0x45
my_struct c  =0x89AB
when it should be
my_struct c  =0x6789
Im sure its something stupid I'm missing but I am stumped on this problem.. and I know microblaze does not support pragma pack.
Thanks for your help in advanced;
Tags (3)
Newbie rmpresto
Re: Help Using __attribute__ ((__packed__)) Microblaze
Sorry Typo:
short x = 0x0001
short y = 0x0203
short z = 0x0405
my_struct c =0x08090A0B
I cannot tell you what is wrong in your case because your code seems incomplete but I am using Microblaze with packed data and in my case, I redefine my structures with "typedef" and it works.
Your case would be:
typedef struct{
  short a;
  short b;
} my_struct;
typedef struct __attribute__((_packed_)){
  short x;
  short y;
  short z;
  my_struct c;
} size;
