Participant hyungdal.kwon
How can I connect from AXI Stream interface to Block RAM?
I want to connect a DMA and Block RAM using AXI Stream interface.
I thought a few kind of method, but I couldn't find the right answer.
I want to move many memory mapped data to block RAM that has read address control port.
My design concept is that the block RAM is configured as simple dual port. So, Another memory controller can access to block RAM.
Thank you for your reading.
Re: How can I connect from AXI Stream interface to Block RAM?
Hi @hyungdal.kwon,
Did you tried to use an AXI interconnect?
Florent
Florent
I want connect like the below.
PS -> DMA -> BRAM
PS <- DMA <- BRAM
Observer rjw_999
yes,you should use DMA to connect between AXI stream and RAM
Stream I/F has no address bus, but BRAM I/F has a address bus.
I solved this issue using DMA.
It's connection is like the below.
PS ->( AXI I/F)-> DMA -> (Stream I/F) -> Stream Data FIFO -> (Stream I/F) -> DMA(same thing) ->( AXI I/F) -> AXI BRAM Controller -> BRAM
If I have more time to optimize this design, I want to modify DMA to eliminate the Stream Data FIFO.
