Observer a1300012709
How can I monitor the power of the board?
I am using ZC706 now. And I use SDSoC to program. Is there some pragma or libraries that can help me to monitor the average power?
Re: How can I monitor the power of the board?
check this post
https://forums.xilinx.com/t5/Zynq-All-Programmable-SoC/ZC706-Power-voltage-and-current-monitoring-barematel-application/td-p/682277
Thanks and Regards
Balkrishan
There is reference for ZC702 in http://www.wiki.xilinx.com/Zynq-7000+AP+SoC+Low+Power+Techniques+part+3+-+Measuring+ZC702+Power+with+a+Standalone+Application+Tech+Tip?responseToken=0ee6220018e361958e0af37c63bfa561b
You have to change driver for zc706 as mentioned in wiki page totest.
regards
Praveen
For measuring/monitoring power for various power supply rails in ZC706 the information in the following AR http://www.xilinx.com/support/answers/39037.html is useful
