Participant diy_a
How can i port .mcs file to ZYBO through QSPI flash?
I have been trying to flash a boot image(.mcs file) to zybo through qspi flash. I have created a boot image with the following files.
1. fsbl
2. bitstream
3. u-boot
4. uimage
5. device tree
6. ramdisk.image.gz
what are the offset values should i given during creating the boot image and
what is the offset value should i given during "Program the flash memory" window box ?
From where should i get those offset values?
thanks in advance.
Re: How can i port .mcs file to ZYBO through QSPI flash?
check this tutorial it may help you
https://reference.digilentinc.com/learn/programmable-logic/tutorials/htsspisf/start
Thanks and Regards
Balkrishan
