Visitor bin9000
How do I use burst transfer using AXI Full interface
If I want to transfer one data with AXI Lite interface, I just typed functions in C code in SDK, which is "Xil_Out8, Xil_In32.."
But I don't know how to use burst transfer.
What functions should I use in C code to use burst transfer?
Re: How do I use burst transfer using AXI Full interface
Hi @bin9000 ,
You might want to search for an answer on the forums before posting as there might be the answer already:
https://forums.xilinx.com/t5/AXI-Infrastructure/AXI-burst-access-to-the-AXI-full-slave-from-Microblaze-is-this/td-p/843235
https://forums.xilinx.com/t5/AXI-Infrastructure/How-Do-I-Perform-an-AXI-Burst-in-Software/td-p/592502
Florent
Hi @bin9000 ,
Florent
Scholar dgisselq
You might find this discussion and comparison interesting.  It goes through a cycle-by-cycle logic explanation showing why a CPUs bus access isn't nearly as fast as the CPU itself.  It also demonstrates CPU logic, albeit not MicroBlaze, that can interact with a bus at one transaction per 10ns cycle for an extended period of time.
Dan
