Visitor dp123
How to Simulate microblaze in XPS tool
can anyone tell how to simulate microblaze  in XPS
I am new to FPGA world. Please help,  its very urgent for my work.
Re: How to Simulate microblaze in XPS tool
Some of the older CTT guides covered simulating edk:
https://www.xilinx.com/support/documentation/sw_manuals/edk_ctt.pdf#page57
Is there a reason you are using EDK?
Visitor dp123
This document is useful but  I am using EDK 14.1
some options mentioned in the documents are not visible in my XPS version
Can you tell just tell how to simulate hello world and print the output on the console terminal
You can few a newer version to see the steps:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx11/edk_ctt.pdf
This might help too
https://www.xilinx.com/support/documentation/sw_manuals/xilinx13_3/platform_studio/ps_p_ise_edk_sim_flow.htm
Note: the simulation in edk required verilog and vhdl simulator license
Visitor dp123
I could not see the hello world in terminal but I am able to simulate the logic correctly.
I think there is some problem in my UART setting.
Hi @dp123,
Check UART baud rate setting and setting in BSP if it is properly mapped to uart which you have enabled.
Praveen
