How to access the old version of document
Hi all
I would like to know how to access the old version of document, ug585 for vivado 2016.2 specifically.
https://www.xilinx.com/support/documentation/user_guides/ug585-Zynq-7000-TRM.pdf
I could not find any link or information about how to access it.
please show me clue.
thanks in advance
Sincerely
amistad
Re: How to access the old version of document
Hi @amistad
For some document, if you seach on Xilinx, you will have the option to find different version of the UG/PG:UG900.JPG
It makes sense because they are specific to a vivado version because some commands are changing.
For the UG585, it does not makes sense to keep the previous version of the document. The document describe the silicon, which is not changing between versions. So each version will only be clarification or errors/typos fixed. So the latest version is always what you should look at.
hi @florentw
the document I need is UG585, and the search result shows there is no "see all versions" as what you show in the replication, UG900.
So, how to access the old version of UG858?
thanks
amistad
Hi @amistad
Please read my previous reply up to the end...
hi @florentw
I encountered an issue for PS-SPI, which configuration does not work correctly as described in the UG585.
cs2 is not pull-low when I set the CR for PS-SPI according to the UG585 while the cs0 and cs1 work correctly.
I wounder if it is a XSDK version issue or something else.
So, should I discuss this problem in another forum ?
thanks
amistad
HI @amistad
You might want to look of Answer Records or forums topics. You might find the answer.
My main recommendation would be to use the latest version of the tool ;)
Here is one AR you might want to look at: AR#58294
