How to create BOOT.BIN out of yocto image & Vivado Design
Hi there,
I have completed a Yocto compilation for a Zynq board (XC7Z10 partnumber) and I have this files as output:
core-image-minimal-dev-zynqberry-20170331102214.rootfs.cpio
core-image-minimal-dev-zynqberry-20170331102214.rootfs.cpio.gz.u-boot
core-image-minimal-dev-zynqberry-20170331102214.rootfs.manifest
core-image-minimal-dev-zynqberry-20170331102214.rootfs.tar.gz
core-image-minimal-dev-zynqberry.cpio
core-image-minimal-dev-zynqberry.cpio.gz.u-boot
core-image-minimal-dev-zynqberry.manifest
core-image-minimal-dev-zynqberry.tar.gz
modules--4.4-xilinx+git0+89cc643aff-r0-zynqberry-20170331102214.tgz
modules-zynqberry.tgz
README_-_DO_NOT_DELETE_FILES_IN_THIS_DIRECTORY.txt
u-boot.elf
u-boot.img
u-boot-zynqberry.elf
u-boot-zynqberry.img
u-boot-zynqberry-v2016.01-xilinx+gitAUTOINC+07b02489f2-r0.elf
u-boot-zynqberry-v2016.01-xilinx+gitAUTOINC+07b02489f2-r0.img
uImage
uImage--4.4-xilinx+git0+89cc643aff-r0-zynqberry-20170331102214.bin
uImage-zynqberry.bin
Now I also have a Vivado design including the Bitstream and HDF files. My doubt is about how I create a suitable BOOT.BIN file that will boot properly my Yocto compilation.
I have found this link, but I'm not able to create the mentioned file...
Also I have found this link saying how to create a SD card with the image.
But as I'm running a PetaLinux BOOT.BIN file, does not understand the kernel I have uploaded. How can I change the u-boot configuration and make a proper BOOT.BIN image??
This is the output of the U-BOOT once I run it:
reading image.ub
** Unable to read file image.ub **
U-Boot-PetaLinux> bootm 0x3000000 - 0x2A00000
Wrong Image Format for bootm command
ERROR: can't get kernel image!
Thanks in advance!
Re: How to create BOOT.BIN out of yocto image & Vivado Design
What you can do is this.
Create a bif file with these three items:
//arch = zynq; split = false; format = BIN
the_ROM_image:
[bootloader]/path-to-fsbl/executable.elf
/path_to_bitfile/bitstream.bit
/path_to_yocto/poky/build/tmp/deploy/images/zynqberry/u-boot.elf
Run the following command line:
$ bootgen -image your_bif_file.bif -arch zynq -o /path_to_bin/BOOT.bin
You may also have a problem with teh FSBL: use this link to create it
--Sebastien
Visitor rajeshvadla
Can you please help me how to build yocto for xilinx xc7z020 board ? I am not seeing any machine config file for this board in meta-xilinx layer so how can we built for this particular hardware.
I am trying this from so many days,i am not getting the correct solution .please help me i think you built for XC710.
Thanks for your reply,
V Rajesh
Visitor rajeshvadla
Hello imuguruza,
I am trying to build yocto for XC7Z010 board ,i copied the zc702 board config file and renaming with this board and this file consists of
UBOOT_MACHINE = "zynq_zc702_config"
SPL_BINARY = "spl/boot.bin"
SERIAL_CONSOLE = "115200 ttyPS0"
KERNEL_DEVICETREE = "zynq-zc702.dtb"
KERNEL_FEATURES += "features/rtc/rtc.scc"
IMAGE_BOOT_FILES += "boot.bin uEnv.txt ${KERNEL_IMAGETYPE}-zynq-zc702.dtb"
So,how can i give xc7z010 board files here like config file and dtb file
V Rajesh
