How to create a boot image for Microblaze
I have built a microblaze system with SPI flash and local memory (non-DDR).  I'm wondering how to build a boot image combining FPGA and microblaze application firmware that loads from the serial flash to on chip local memory and runs from the local memory.
I use Vivado 2013.4 to generate the bit image and SDK to generate the application firmware.
Henry
Re: How to create a boot image for Microblaze
Hi Henry
Refer to http://www.xilinx.com/support/documentation/application_notes/xapp1176-xip-axi-quad-spi-ipi.pdf
--Hem
Hem,
Thanks for your link.
Henry
Hem,
I downloaded the example design and run the all.tcl to generate the block design.  There is an error message:
ERROR: [Common 17-55] 'set_property' expects at least one object.
    while executing
"rdi::set_property offset 0xC4000000 {}"
    invoked from within
"set_property offset 0xC4000000 [get_bd_addr_segs {/microblaze_1/Instruction/SEG14}]"
    (file "C:/svn/IZ_Corp/kc705_xip_quad_mode/HW/all.tcl" line 285)
I am wondering how to fix it.
Henry
Hi Henry
The XAPP was built for 2013.2  so have a look at the hardware and create this as a new design in the version that you are using.
--Hem
Observer kpiter
the same error with vivado 2013.2
Also I got warnings before error:
WARNING: [BD 5-234] No nets matched 'get_bd_nets /Net4'
# connect_bd_net -net [get_bd_net /Net4] [get_bd_pins /axi_intc_1/Processor_rst] [get_bd_pins /proc_sys_reset_1/MB_Reset]
# connect_bd_net [get_bd_pins /proc_sys_reset_1/Bus_Struct_Reset] [get_bd_pins /lmb_v10_2/SYS_Rst]
WARNING: [BD 5-234] No nets matched 'get_bd_nets /Net5'
# connect_bd_net -net [get_bd_net /Net5] [get_bd_pins /lmb_v10_1/SYS_Rst] [get_bd_pins /proc_sys_reset_1/Bus_Struct_Reset]
# connect_bd_net -net [get_bd_net /Net5] [get_bd_pins /lmb_bram_if_cntlr_1/LMB_Rst] [get_bd_pins /proc_sys_reset_1/Bus_Struct_Reset]
# connect_bd_net -net [get_bd_net /Net5] [get_bd_pins /lmb_bram_if_cntlr_2/LMB_Rst] [get_bd_pins /proc_sys_reset_1/Bus_Struct_Reset]
Community Manager
Community Manager
You can follow the steps given in http://www.xilinx.com/support/answers/63605.html
Please feel free to modify the linker script to run SREC bootloader from Microblaze local memory and user application from BRAM or viceversa.
