Observer ddtang
How to generate an interrupt in the AXI Interrupt Controller in a baremetal application?
I've been trying to generate an interrupt from a baremetal application on the PS side of a Zynq-7000 system using a AXI Interrupt Controller, but it doesn't seem to be working.
I'm writing an interrupt to the ISR register but the handler isn't being calling.
Does anyone have any hints on how to get the interrupt to work? Thanks!
Re: How to generate an interrupt in the AXI Interrupt Controller in a baremetal application?
Hi @ddtang,
Which PL peripheral in Zynq is used to generated the interrupt request?
Let say it is Uartlite, then connect uartlite irq line directly to PS GIC i.e. PS irq port and there is no need of AXI Intc at all.
There are example in SDK for every peripheral to test interrupt.
Praveen
So you have axi intc connected to PS irq inputs?
If so, you need to make sure to service the correct irq input to the PS. Then, in the axi interrupt controller, make sure you have the correct bit set in IER (or SIE), and you have master enabled in MER.
