How to guarantee PS DDR bandwith from a custom AXI master IP in the PL on a Zynq UltraScale+ device
Hello
a customer needs to have 8Gbps write speed from his custom AXI master IP in the PL.
He is targeting a LPDDR4 on the PS (similar hardware as on the Ultra96)
When a software task in the PS is running a memory intensiv application the write speed of the IP in the PL is affected.
There was a thread asking for the documentation of the PS DDR service registers which might be a solution:
https://forums.xilinx.com/t5/Embedded-Processor-System-Design/Zynq-UltraScale-PS-DDR-quantity-of-service-registers-for-AXI/td-p/886298
Can someone please give an update on this?
Marco
Re: How to guarantee PS DDR bandwith from a custom AXI master IP in the PL on a Zynq UltraScale+ device
Hi marco.hoefle@avnet.eu ,
Please verify PS DDR (DDRC) register details in UG1087.
Praveen
Hello Praveen,
thank you for your hint.
It is not clear to me how to use the DDRC registers for controlling the priority.
I looked at
PCTRL_0
PCFGW_0, is the wr_port_urgent_en what you mean?
PCFGQOS0_0
PCFGQOS1_0
PCFGWQOS0_0
PCFGWQOS1_0
Can you explain in more detail -  based on the memory overview below - how to ensure that for example S_AXI_HP0_FPD has priority?
Thank you
Marco
DDR QoS settings in GUI will be presented in Advance Configuration page with new
node "DDR QoS Configuration" under advance configuration mode.
DDR QoS feature has already been supported starting from 2017.3 with using
"set_param pcw.enableddrqos {1}" TCL parameter.
The page will be mainly classified into two categories
1. AXI Port classification :
2. CAM Threshold level :
QoS programming will be written in separate proc in psu_init.c/tcl. The new proc name will be "psu_ddr_qos_init_data()".
Then you can find how these Qos registers are set.
Also you can change the QoS setting and use the system performance monitor to measure the performance.
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842421/Zynq+UltraScale+MPSoC+-+System+Performance+Modelling
