How to program mcs/bit using SDK flash tool ?
How should I program .mcs file (or .bit file) using SDK flash tool ?
I have tried it and it does not work ( but same .mcs file programmed in another xilinx hw tool - works)
What should I put in start address ?
Should I enable anything in the window options ?
Why the tool does not recognize .mcs file (only .bin, elf) ?
Thank you,
Ran
Re: How to program mcs/bit using SDK flash tool ?
If you would want to program the BPI Flash memory for a Microblaze system you can refer to
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_3/SDK_Doc/tasks/sdk_t_program_flash.htm
If this is for Zynq, refer to page 45 of this document
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_3/ug873-zynq-ctt.pdf
--Hem
Thank you very much for the reply.
I am trying to program .mcs or .bit file (which contain the fpga, and application). It works when we program it using iMPACT, but on trying to program the flash with the flash tool (in sdk) , it does not work.
Can you please advise,
Ran
Hi Ran
We would need some more details. Is it a Serial Flash/BPI Flash?
Is there a DDR in your design?
If this is a BPI flash, refer to the procedure mentioned here. http://forums.xilinx.com/xlnx/attachments/xlnx/EDK/5498/1/Flashwriter_101.pdf
--Hem
I'm not sure I know the answers for this questions.
In xparameters.h I see:
/* Xilinx EDK Parallel Flash Library (XilFlash) User Settings */
#define XPAR_XFL_DEVICE_FAMILY_INTEL
and system.mss is as following:
PARAMETER VERSION = 2.2.0
BEGIN OS
PARAMETER OS_NAME = standalone
PARAMETER OS_VER = 3.11.a
PARAMETER PROC_INSTANCE = microblaze_0
PARAMETER STDIN = debug_module
PARAMETER STDOUT = debug_module
END
BEGIN PROCESSOR
PARAMETER DRIVER_NAME = cpu
PARAMETER DRIVER_VER = 1.15.a
PARAMETER HW_INSTANCE = microblaze_0
END
BEGIN DRIVER
PARAMETER DRIVER_NAME = axicdma
PARAMETER DRIVER_VER = 2.03.a
PARAMETER HW_INSTANCE = axi_cdma_0
END
BEGIN DRIVER
PARAMETER DRIVER_NAME = intc
PARAMETER DRIVER_VER = 2.06.a
PARAMETER HW_INSTANCE = axi_intc_0
END
BEGIN DRIVER
PARAMETER DRIVER_NAME = tmrctr
PARAMETER DRIVER_VER = 2.05.a
PARAMETER HW_INSTANCE = axi_timer_0
END
BEGIN DRIVER
PARAMETER HW_INSTANCE = axi_timer_1
END
BEGIN DRIVER
PARAMETER DRIVER_NAME = uartlite
PARAMETER DRIVER_VER = 2.01.a
PARAMETER HW_INSTANCE = debug_module
END
BEGIN DRIVER
PARAMETER DRIVER_NAME = generic
PARAMETER DRIVER_VER = 1.00.a
PARAMETER HW_INSTANCE = fabric_mm_0
END
BEGIN DRIVER
PARAMETER HW_INSTANCE = fabric_mm_1
END
BEGIN DRIVER
PARAMETER DRIVER_NAME = emc
PARAMETER DRIVER_VER = 3.01.a
PARAMETER HW_INSTANCE = generic_external_memory
END
BEGIN DRIVER
PARAMETER DRIVER_NAME = iic
PARAMETER DRIVER_VER = 2.08.a
PARAMETER HW_INSTANCE = generic_iic_bus
END
BEGIN DRIVER
PARAMETER DRIVER_NAME = spi
PARAMETER DRIVER_VER = 3.06.a
PARAMETER HW_INSTANCE = generic_spi
END
BEGIN DRIVER
PARAMETER DRIVER_NAME = bram
PARAMETER DRIVER_VER = 3.03.a
PARAMETER HW_INSTANCE = microblaze_d_bram_ctrl_0
END
BEGIN DRIVER
PARAMETER HW_INSTANCE = microblaze_d_bram_ctrl_1
END
BEGIN DRIVER
PARAMETER HW_INSTANCE = microblaze_d_bram_ctrl_2
END
BEGIN DRIVER
PARAMETER HW_INSTANCE = microblaze_i_bram_ctrl_0
END
BEGIN DRIVER
PARAMETER HW_INSTANCE = microblaze_i_bram_ctrl_1
END
BEGIN DRIVER
PARAMETER HW_INSTANCE = microblaze_i_bram_ctrl_2
END
BEGIN DRIVER
PARAMETER HW_INSTANCE = uart_0
END
BEGIN DRIVER
PARAMETER HW_INSTANCE = uart_1
END
BEGIN DRIVER
PARAMETER HW_INSTANCE = uart_2
END
BEGIN LIBRARY
PARAMETER LIBRARY_NAME = xilflash
PARAMETER LIBRARY_VER = 3.04.a
END
Please advise,
Ran
hi
looking at the mss it looks that there is no external memory. so you can still use the pdf that i referred in the last post.
--Hem
MicroController user 8-bit memory, where as flash usea 16-bit memory.
so when using iMPACT if you specify the offset address from where it should start storing your .srec file(elf converted to serc) as 0x00500000, then theoffset address that you would have to specify in sdk bootloader will be 0x00A00000.
If you are facing problem when programming using sdk tools: try deleting .bit, .elf, .srec, flash.tcl files and regenerate them.
Now to program a fresh. It should work. I faced the same problem.
