Visitor abhi1893
How to read/ write from Zynq 702 PS to DDR3 SDRAM using Xilinx SDK
I am a newbie to Xilinx SDK. I am trying to build an application which takes input from UART and sends the data to DDR3 using only PS(no PL involved). Is there any example/reference I can consult? I am unable to find any examples in the SDK documentation  for the same.
Tags (4)
Scholar hbucher
Re: How to read/ write from Zynq 702 PS to DDR3 SDRAM using Xilinx SDK
@abhi1893 What DDR3? PS (ARM) side or PL (FPGA) side?
If PS-side, from the PS perspective the UART is (often) mapped to stdin and stdout - so nothing new to you here.
And the DDR3 PS-side is just another memory. Get its base address in the Address Editor but be careful not to write on top of your executable.
So all you need to do is read from stdin and write to that base address (plus offset).
Visitor abhi1893
DDR3 on the PS side.
What function do I need to use for wrting to the base address of DDR3?
Scholar hbucher
@abhi1893 Nothing, just regular C.
int* array = (int*)MY_BASE_ADDRESS;
while ( 1 ) {
   u32 val = < read from stdin >;
   array[pos] = val;
   pos += 4;
Or fill up a buffer and memcpy() it. Up to you.
Visitor abhi1893
Thank you. Will the same method be applicable when reading from the memory as well?
Scholar hbucher
@abhi1893 Everything behaves as memory.
By the way, you can also dump a file from the host into the PS memory using XSCT (debug console) without any programming on the PS side using the command 'mwr' - see page 25 on UG1208
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_2/ug1208-xsct-reference-guide.pdf
