How to store the data received through the Ethernet(RJ45) in a file. (data is displayed in Hercules setup utility)
I'm working on Zynq Ultrascale+ ZCU102 ES2 board. I have generated a block design in Vivado with Zynq MPSoC and AXI BRAM controller. I have loaded the data in the Block RAM as a coe file. Then launched the SDK with lwIP echo server template, modified the echo.c file to access the BRAM data and using tcp_write I have sent the data. Using the Hercules Setup Utility I connect to the TCP client with the Board IP and the BRAM values are displayed there.Where can I store this recieved values (the values displayed in the Hercules Setup ).
Now how do I handle this data where and how can I store this data in a file so that I can access this data as a file later.
Thank you.
