How to switch from MicroBlaze standard to fast interrupt
I have a working design with Microblaze which uses an interrupt:
void InterruptServiceRoutine1(void *InstancePtr)
   printf("InterruptServiceRoutine 1\n\r");
void InterruptServiceRoutine2(void *InstancePtr)
   Watchdog *Watchdog = &Watchdog::getInstance();
   printf("InterruptServiceRoutine Anfang 2\n\r");
   for (int i = 0; i < 4; i++)
      Watchdog->trigger();
      usleep(500000);
   printf("InterruptServiceRoutine Ende 2\n\r");
int main(int argc, char **argv)
   init();
   Watchdog *Watchdog;
   PowerSupply *PowerSupply;
   FPGA_ClockGenerator *ExternalClockGenerator;
   int Status;
   if (not systemInfo->isSimu)
      printf("-- Start standard --\n\r");
      PowerSupply = &PowerSupply::getInstance();
      PowerSupply->switchOnDigital();
      msleep(10); // Wait until power is ramped up
      ExternalClockGenerator = &FPGA_ClockGenerator::getInstance();
   mmapaccess->WritePara(100000000, RegMB_BC_MicroBlaze_IRP_Timer_IRP_Timer, 0);
   mmapaccess->WritePara(300000000, RegMB_BC_MicroBlaze_IRP_Timer_IRP_Timer, 1);
    Status = XIntc_Initialize(&InterruptController, XPAR_INTC_0_DEVICE_ID);
    if (Status != XST_SUCCESS) {
      printf("Initializing interrupt controller failed\n\r");
    Status = XIntc_Connect(&InterruptController, XPAR_AXI_INTC_0_SYSTEM_INTR_0_INTR,
              (Xil_ExceptionHandler)InterruptServiceRoutine1, &InterruptController);
        return XST_FAILURE;
    Status = XIntc_Connect(&InterruptController, XPAR_AXI_INTC_0_SYSTEM_INTR_1_INTR,
              (Xil_ExceptionHandler)InterruptServiceRoutine2, &InterruptController);
        return XST_FAILURE;
    Status = XIntc_Start(&InterruptController, XIN_REAL_MODE);
        return XST_FAILURE;
    XIntc_Enable(&InterruptController, XPAR_AXI_INTC_0_SYSTEM_INTR_0_INTR);
    XIntc_Enable(&InterruptController, XPAR_AXI_INTC_0_SYSTEM_INTR_1_INTR);
        return Status;
   Xil_ExceptionInit();
   Xil_ExceptionRegisterHandler(XIL_EXCEPTION_ID_INT,
      XIntc_InterruptHandler,
   Xil_ExceptionEnable();
   main_loop(Watchdog);
   return 0;
What do I have to do in oder to switch to fast interrupt mode? I set "Enable fast interrupt logic" in the Vivado Microblaze design. The design still works with no difference using the code above.
I'm using https://forums.xilinx.com/xlnx/attachments/xlnx/EMBEDDED/31646/1/main.c as a template for using fast interrupt mode. The code below doesn't work however. It prints "Before connect handler" then the watchdog runs into a timeout. What am I doing wrong?
void InterruptServiceRoutine1(void *InstancePtr) __attribute__((fast_interrupt));
void InterruptServiceRoutine2(void *InstancePtr) __attribute__((fast_interrupt));
      usleep(500000);
   init();
   Watchdog *Watchdog;
   int Status;
      printf("-- Start fast --\n\r");
   printf("Before connect handler\n\r");
    Status = XIntc_ConnectFastHandler(&InterruptController, XPAR_AXI_INTC_0_SYSTEM_INTR_0_INTR,
              (XFastInterruptHandler)InterruptServiceRoutine1);
   printf("After connect handler\n\r");
        return XST_FAILURE;
    Status = XIntc_ConnectFastHandler(&InterruptController, XPAR_AXI_INTC_0_SYSTEM_INTR_1_INTR,
              (XFastInterruptHandler)InterruptServiceRoutine2);
        return XST_FAILURE;
   XIntc_Enable(&InterruptController, 0);
   return 0;
Re: How to switch from MicroBlaze standard to fast interrupt
Hi @qmarc,
Could you try the attached code?
Praveen
Thanks for the example design. It appears to be for Zynq, not for Microblaze however. For this reason fiqasm.S doesn't compile in my design. Is it available for Microblaze as well? Or in C instead of assembler?
Best Regards,
Michael
